custom dash/instrument cluster
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mdevlin, Feb 9, 2004.
  1. mdevlin
    mdevlin Registered Member
    Dec 1, 2003
    68
    Massachusetts
    I have been working on a never ending rebuild on my 84 blazer. The biggest piece (in my mind) involved ripping all the wiring and the fuse box out, and installing a snazzy new painless wiring fuse box/wiring harness kit.
    The problem i am running into is making the new setup not look like a hack job. I got all new autometer gauges to fix the broken non-working stock ones that came with the blazer, and I decided to run a painless toggle switch panel instead of using the keyed ignition on the steering column, so basically...
    I am trying to figure out the best way to mount all the new autometer gauges, and the switch panel. It seems to me I am going to have to fabricate out of sheet metal a whole new dash, because modifying the stock instrument cluster to fit the autometer gauges ended up looking horrible. I basically dremel'd out all the holes in the instrument cluster to fit the larger non-circuit board style gauges, and cut a face plate that screwed over the plastic instrument cluster panel to make it look a little less messy, but it still looks crappy.
    What I am envisioning is a whole new dashboard made out of sheet metal, with the automater guages bolted right down to the sheet metal, and then 2 hole cut out for a radio and the 6 toggle switch control panel. It seems "simple enough" but I am having trouble figuring out how to tie in this new panel to the curvy stock dashboard. Has anyone done any other custom dash jobs like this? any ideas/comments would be appreciated, this is pretty much the last step in a going on 3 year buildup, and I am kinda stuck in a nice deep hole I dug for myself.
    BTW: my backup plan was to figure out something to screw into the exisiting instrument cluster location, and put all the autometer gauges on that. the use the hole for the A/C controls for the 6 switch panel, and use the radio hole for the radio, and call it a day, but it just seems like that isn't the best way...
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    This a little overkill! AutoMeter Setup! Bling, Bling! [​IMG]
    This is TWEETYSUARUS's dash. all custom dash.
    I have autometer guages, but am making panels to put them in that will fit in the stock bezel. for a more stock look. I don't have any completed pics. I can still use the stock dash pad with mine.
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    What would you do with the a/c and heat vents? /forums/images/graemlins/doah.gif
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  5. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
  6. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    What I am doing is very similar to the first set of pics. But i had to move my guages around. I couldn't use the 2 guages on the far left. My roll bar tubing blocked them. Si am using the smaller 3 3/8 speedo/tach and putting guages on the right side also. I am still using all the stock heater parts. I don't think tweetysyarus cares about the heater.
  7. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Hey now! /forums/images/graemlins/ignore.gifI have a heater and defroster! Works really great too! Just didn't want it blowin in my face!
    Bill
