Custom doubler need a body lift?
Discussion in 'OffRoad Design' started by MaxCrack, Sep 25, 2003.
  1. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    OK, I am saving up (still*) for a custom doubler. I will be putting a Ford 205 to a Chevy 203 to match the Ford D60. I would like to clock it up 2" so it is close to flat. Now, do I need any more space under the body? I have a chance to get a 1" body lift for cheap. I'd rather not use it if I dont need to, but I would like to be prepared incase I ever save enough money /forums/images/graemlins/wink.gif for the doubler.
    *I had $700 saved up, but I blew up the rear end (axle shaft in a dually Dana 70) and decided to spend the cash on a 14 Bolt with detroit and gears to match the front end. I'm back up to $300 though. I'm getting there.
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Definitely get the 1" body lift, I have a 2" and I am about an inch from the floor. I might actually just cut the floor so I can lower the body back down.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The 1" never hurts, that extra room lets you play around with how far up you push the transfer cases and things like that so it's definitely something to consider. And it makes it really easy to work with things like the bell housing bolts and other hard to reach items under the truck.
  4. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    so you still need the doubler kit right? /forums/images/graemlins/confused.gif
    But then won't you need two spares, 8 lug ford rim and chevy arn't the same /forums/images/graemlins/ears.gif
  5. supersize75
    Sep 27, 2002
    2,638
    But then won't you need two spares, 8 lug ford rim and chevy arn't the same /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif
  6. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    only the new f-rod lug patterns are diff ie stupiduty. /forums/images/graemlins/deal.gif
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Silly Shawn, only Superduty Fords need different 8 lug pattern. /forums/images/graemlins/rotfl.gif All older Ford, Dodge, and Chevy run the same 8 lug pattern. 8 on 6.5" I believe is the size.
  8. supersize75
    Sep 27, 2002
    2,638
    well now I know /forums/images/graemlins/thumb.gif
  9. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Ford/ Dodge 8 on 6.5" rims have a larger hub pilot hole than Chevy's. You can use a ford rim on a chevy but not the other way.
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I have used both dodge and ford rims on a chevy before, the center holes are different sizes like you mention but they all worked on my chevy, and yes they were a 8 on 6.5" bolt circle.
