custom front springs
Discussion in 'OffRoad Design' started by k5texan, Aug 6, 2002.
  1. k5texan
    k5texan 1/2 ton status
    Aug 1, 2001
    119
    Flint, TX
    i was wondering what a set of your custom front springs would run with about 4 inches of lift.
    thanks
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Front and rear, approx $950.00. Lift height is basically your call but we rarely go over about 6" of lift or about 15" of ride height. (measured from the bumpstop bracket to the top of the axle tube in the front suspension) Your 4" height will work great.
  3. k5texan
    Aug 1, 2001
    119
    Flint, TX
    thanks
  4. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I saw those Alcan's put to use this weekend and watched BOSS bend the mainleaf in his rear pack when he backed his shackle into a rock. Here is a pick.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Backing into a rock with the shackle is usually bad. Kind of like turning left and backing up with GM steering on a front end. Guaranteed to make a taco of your main leaf.
    We should also be clear on the lineage of these springs: Alcan really has little to do with them. They build to my specs and are only responsible for defects in workmanship or material. And incidently we don't have problems with either. Since they're completely to ORD specs, settling and other design or performance issues are our problem, not Alcan's.
  6. bigbluek20
    bigbluek20 1/2 ton status
    Dec 18, 2001
    119
    Loveland, Colorado
    Stephen,
    Can you elaborate on the "backup while turned left making a taco of the frong spring"?
    I am now riding on my second sagging skyjacker (front left) and am very dismayed. Could this be something caused by backing while turned? I am frequently backing trailers with tight turns.
    Steve
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The GM steering relies on the left front spring to counter the steering forces and make the tires actually turn. If the draglink is pulling forward (turning left) you have a compressive load on the spring and a piece of flatbar with a curve in it (leaf spring's main leaf) is not very good at resisting these stresses, so it bends. Backing up only makes it worse since the tire will often be trying to climb something and that adds more compressive load to the spring's front section. Ask Fox about this, his Rancho's still have a kink in them from this problem.
    As for your backing up trailers, I don't think it would be a problem unless you're backing up in some really hairy conditions.
