Custom Gas Tank
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazr77400, Nov 7, 2001.
  1. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    I am getting one built, but I just need to know if Radiator hose would be okay for the filler neck. Its on a truck and the gas tank will be in the back tucked up in the frame. I am going from the stock Gas door location to the tank and just need to know if its Okay.
    4 wheeling is like sex, when its good, its really, really good, when its bad its still pretty good.
  2. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    From what I understand, radiator hose won't hold up to gasoline. You really should run a hose that is designed for the purpose. <a target="_blank" href=http://www.lmctruck.com>LMC Truck</a> now sells the filler hoses for stock applications. Although you are doing some custom work, you may be able to adapt the stock pieces to work for you.
    Robb
    '73 GMC Suburban - 502DFI
    <a target="_blank" href=http://community.webshots.com/user/robbrj>community.webshots.com/user/robbrj</a>
