Custom rear bumper with swing out tire carrier
Discussion in 'General Parts for Sale' started by 88K5Jimmy, Dec 15, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Main bumper is 3"x4" 1/4" wall rectangular tubing and the swing out tire carrier is 2"x2" 1/4" wall square tubing.
    Specs:
    -high lift jack tabs on ends to jack the truck up
    -pad lock lockable swing our tire carrier
    -wiring for a back-up light and license plate light
    -professional bedliner coated by Ameriguard in Tulsa
    -greasable hinge
    -pad lock lockable spare tire
    -utilizes tailgate torque rods
    -receiver box and rings
    The spare mount is set up to accept a 31" tire. You would have to move the all thread and re-weld it to accomodate a bigger tire. The carrier was designed to hold a 38" tire. So the outer diameter of a 38" tire will be approximately even with the top of the tire carrier. The mounting brackets extend all the way to the rear of the spring hangers. If you have an ORD flip in the rear you will have to trim a little off the mounting brackets because the ORD flip sits wider on the frame than the factory spring hangers.
    I have never had any problems with the bumper or tire carrier and it is very solid.
    Located in Tulsa, OK. $250
    Ross
  2. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    You've got a PM.
  3. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Email replied
