Custom Saddling Tubing question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by laketex, Sep 13, 2001.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    As some of you know, i'm in process of making a cage. Got a bender and a notcher and I've made the main hoop, rear hoop, and rear rack. But now I need to make some braces that go in at a diagonal. Basically a 45. I need to put a small notch on one side and about a 45 degree notch from the other one's ends in a cup into the tubing. Those that have done this know what i'm talking about. Now I assume you dont use a torch because of heat issues. So what do I use to mark and to cut?
    Sherman, Tx
    <font color=red>THE OFF- ROAD GOES ON FOREVER AND THE PARTY NEVER ENDS!!
    </font color=red>
  2. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I built a tire carrier using tubing. I cut the notches you are talking about using a grinder, just went a little at a time and kept putting in a piece of tubing till I had it right.
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  3. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    Although it isn't exactly inexpensive, a tubing notcher is what I've seen used before. Since you have already invested in welder, tubing bender, etc, you may want to get one to complete the kit. [​IMG]
    Eastwood Company sells a nice one that you can see community.webshots.com/user/robbrj
  4. laketex
    6,220
    North Texas
    wow that is nice, 502. I'll definately keep it in mind when I buy a bender and welder of my very own. Living with borrowed property right now [​IMG]. We've got a notcher but it only does 1-3/4 which is fine, but it also only does straight in notches. I'll probably end up using a cut off wheel and a grinder. perhaps that'll work ok.
    Sherman, Tx
    </font color=red>
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Check out My vehicles
