Custom spring setups
Discussion in 'Center Of Gravity' started by BadDog, Mar 18, 2001.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ok, I'm pulling this out of the "Lifts that don't ride like crap" thread. I got interested in it and sorta hijacked the thread discussing it with Donovan. Anyway, I thought I would throw it out here for general viewing. Sorry, I know it’s generally frowned on to hijack a thread and go off-topic, but it didn’t start that way. [​IMG]
    I'll post the relevant history from the other thread below in chronological order separated by “--------------------“
    The best riding springs are going to be a spring that is longer than a stock one. What I mean is the shackle angle is very important. The more straight up and down the worst it will ride. The more it is kicked to the back the better it will ride. That is assuming that you have a positive arch spring. Look at my web page and you can see the longer shackles and they mount at about 45 degrees to the back. http://www.rustbucket.coloradok5.com/photo.htmlThis makes for a super smooth ride. Also my buddy with the red blazer in the pictures is getting longer top leaf to install on his tuff country setup. This should smooth out the ride and give him more flex.
    Donovan
    Bigger is Better
    Cool, I never thought about that but I guess I can see why it would work. If the shackle is vertical, the forces caused by the axle moving closer to the frame will be directed straight into the frame. Only the dearching of the spring will cause the shackle to move past it’s vertical position. When the shackle is already angled to the back, in the direction of spring extension, then forces caused by the axle moving toward the frame will be converted through leverage to sort of "stretch" the spring out effectively reducing it's spring rate. In the other direction, the forces of the axle moving away from the frame will be directed into the increased arching of spring rather than simply pulling straight across the shackle (which of course is not going to stretch).
    I like it, make the existing forces work for you through leverage.
    So, let me see, you took 84 Cherokee main leafs, an add-a-leaf, and a 77 Wagoneer main stack to build your front springs. I guess the width and pin location is already about right for the Chevy? Did you make those shackles? Does that extra hole have a purpose?
    Those spring rockers look interesting too. Simple concept, should be easy enough to make.
    Any down sides to the longer springs OR the spring rockers? I guess it reduces the load carrying ability but off hand I don’t see anything else. I’m tired and I may have missed something but, it looks like I have just found another trick for my project. Thanks…
    Nice ride.
    Bad Dog
    No I don't see any side effects to the longer front springs at all. They are 23" from the front spring bolt to the center pin. Stock chevy is 23.5". So that is okay. The shackles are made by me out of 3/8" plate. The extra hole will be for a brace like the Hill Shackles have. The bushing in the cherokee springs are a metric size. The bolts was 14 mm so what I did is drill the bushing out .011" to 9/16" size. This is now 9/16" front and back. These shackles are 6.75" long but they need to be a little longer because the hit the frame but it is not that bad. I will probably leave them the way they are. The measurement from the bumpstop to the top of the axle is 12.5" which is about 4" lift. If you need the measurements on the shackle let me know and I will make you a drawing of them. If you have any question let me know.
    Donovan
    On the shackles, thanks! I don't need a drawing, just the hole to hole. Is the 6.75 you mentioned hole to hole? You think 0.5" longer would fix the frame clearance problem?
    Also, moving the axle forward a bit is one of the things I wanted to do anyway so 0.5 shorter is 0.5 in the right direction. I was planning on using BDS or TC 4" lift. I wonder if I could get them to provide a longer main leaf? If so, wonder what it would cost? I think I'll call their tech line...
    Bad Dog
    Yes it is 6.75 from center to center. I was think about making 7.25" long ones. So you are right on the money.
    Donovan
    What about those spring rockers? How much difference (good/bad) have they made? Looks like a simple concept. Basically make a hinge out of really strong stuff with the pin running parallel to the spring, bolt the bottom to the axle using short u-bolts, and the top to the normal spring plate using bolts/studs. Do you have a better picture(s) of them? It would be nice to machine some straps (like on some u-joints) to replace the u-bolts and then use studs in the hinge with nuts on the straps so that the lower plate would not need to be so wide to clear the u-bolt nuts. However, the design would have to be right so it did not create a hang point problem like spring under setups tend to have.
    I guess the thickness would work more pretty much like a block which could cause additional axle wrap but the whole thing should not be over 1-1.5" tall so it should be ok. I don't know if I would trust those things on the street but it might be really cool on a dedicated rock ride...
    Bad Dog
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    This is the kind of stuff I'm here for, fantastic! I read that post earlyer and have past it over since, thanks for tagging it Baddog. I don't think you can go wrong with longer leafs (too a point).
  3. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I've also been following the thread. The only drawback I can see with the pivots might extra body roll. No big deal on a trail only truck, also they could probably be pinned for street use.
    Donovan has posted his 'recipe' for his front springs, as well as pictures of how his beast flexes, a couple of times before. Pretty impressive stuff! Its got me looking for Wagoneer springs etc. I'd get right on it but I have to focus on body work for the mean time.
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  4. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    Well guys I am still testing the rear pivots out. Yes they do have more body roll but I really don't have a problem with it. That is the best pictures I have of them. I got them as a test mule from http://www.rustbucket.coloradok5.com
    Bigger is Better
  5. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Sweet! Keep us all posted....
    Rene
  6. Donovan
    524
    Arvada, CO
    Here is a quick little picture I draw to show you what I have in mind to lock the rear pivots from moving while on the street. Look here, I hope that you can see it. http://www.rustbucket.coloradok5.com
    Bigger is Better
  7. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Your kid draw that? (just kiddding), looks like it would be ok, would have to be yery ridged.How about two pinsoff the axle, a left and right, too take the stress off just ine? Your mission, if you chose, is to get it handled and let us know. We take no responsibility and will decline any knolahge of this post. Good luck.
    TwiZtid
  8. Donovan
    524
    Arvada, CO
    Yes you could mount two brackets one on each side and that would be fine. Yes I chose to take that mission.[​IMG]
    So liked the drawing? HEHE[​IMG]
    Donovan
    <A target="_blank" HREF=http://www.rustbucket.coloradok5.com>http://www.rustbucket.coloradok5.com</A>
    Bigger is Better
  9. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Better yet; why not a panard bar? Anything wrong with that? discannect it for the hills, tie it in for the streets.
  10. Donovan
    524
    Arvada, CO
    A panhard rod will not help any in this setup. The panhard rod is used to keep the axle from moving side to side. The next best thing to my drawing would be a rear sway bar. Then you could use sway bar disconnects.
    Donovan
    Bigger is Better
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm making this post just to add a few more thoughts I had on how/why this works so well and to bring it current since there has been more discussion on this in other recent thread. I'm just pasting my post from the other thread into this one.
    &lt;paste&gt;
    On the shackles, there were two things discussed on the old thread where I first saw Donovan's setup. One, of course, is to clear the frame. The other was to help with the ride and spring deformation. With a longer shackle angled back to the spring eye, the action of spring compression is converted to leverage that actually aids in de-arching the spring. The reverse is true when the axle starts down in droop. The downward pull causes the angled shackle to move toward the front increasing the pressures on the spring which ultimately result in increased arch. This affectively reduces the spring rate a bit without running softer, weaker springs. Now, that may not be a perfect explanation but that is what I think I understand about it. We discussed this at length on an earlier thread.
    Oh, and one other thing. If you visualize what happens in droop you will see that without the shackle beginning it's movement angled back, you will reach a point where the axle pulling down on the spring can not arch it any more because the spring is pulling straight along the shackle. Since the front is mounted solid, the axle can not move down any further without bending the spring into a V rather than a smooth arch. The net result of angling the shackle back would be a deeper droop with the spring remaining in a normal arch. This in turn results in better articulation with less stress on the springs (I think, unless I'm missing something). I'm no expert on this and I've never done it, I'm just trying to think/visualize my way through to an understanding. This is something I have every intention of trying on my current project as soon as I get around to it.
    &lt;/paste&gt;
    Bad Dog
  12. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    BadDog,
    When I built my front "buggy spring" I angled the shackles straight up and down. I figured by doing this there wouldn't be much resistence while tucking the suspension. I also used greasable bolts and bushings and just made them snug tight. I then put extre nuts on each bolt so they couldn't backoff. It rides much better than it did before, plus it tucks very well. Take a look at this guys website, he has some type of tractor parts on the back of his willys.http://wildwillys47.homestead.com/Index.html
    David.
    GOT ROCKS?
  13. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    BadDog- you techno guru. What a guy!
    So if I'm think'n right. The shackle should follow the spring threw its front to back swing, not against it. If thats what your talking about then I'm down with that. Thats one of the reasons I swpped over to the longer springs. The A.M. lift springs are to short and put the front shackle angle pointing towards the front end and makes the spring work against the shackle not with it. What I was trying to ask on the other post was; -Is there a spacific length shackle that matches a spacific spring length?- Now that I'm sitting here thinkng about it, I don't think so. Just as long as it clears the frame and works with the spring. Agreed? Any other thoughts? Since mine is still sitting in the grage, I'm kinda wondering how the side loading and stability will be with the longer shackles and angled back.
    Twiztid
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, I guess it would be a completely different thing with the buggy spring setup (still having a hard time adapting to that term, I keep seeing 3/4s! [​IMG]). That top spring pulling down arches too so the shackle would tend to stay more vertical. Even if the shackle did eventually line up with the lower spring arch (which would tend to stop a normal suspension), the upper would just bend more to allow it to continue drooping. I’ll bet a combination of the two approaches would give even more flex. You could test that easily enough by making a second short leaf a bit shorter if you were inclined.
    It would also be interesting to see an actual contact pressure graph based on the amount of droop in the short leaf. I wonder how fast it falls off. You could make a base line by locking the short leaf to the frame (strap?) and lifting the other tire (forklift?) until contact pressure drops to zero. Then do the same with the short leaf free to work. Comparing the graphs would show a better picture than just an RTI score type of thing. No doubt it gives better droop, I just wonder how much it really helps with capability.
    Man, that jeep has some wicked trick stuff under there. Sort of like those spring rockers from BC Bronco but on the shackles. That looks like the ball sockets on a 3 point hitch used for attaching impliments. Cool idea.
    Bad Dog
  15. 80blazer
    80blazer Registered Member
    Mar 4, 2001
    41
    glendale arizona
    I got two questions did Donovan use the original holes for the shackle and how did he figure out where the spring eye needed to be located for the longer front spring. I know he probable has already answered these questions but if he is going to make cool stuff then he is going to get dumb questions. Thanx Jeff 80Blazer
    Its time to lock them in!
  16. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Good job with bring this one back up baddog, can you pull that last pic from donovan's last reply on "buggy spring" to this post. Like to keep all this stuff in one place.
    Also; A contact pressure graph would be good if you had acsss to one, but how much is it worth in te real world? How much flex does a guy realy need? It's cool to say its got XX amount of travel but do you realy need it? What I'm saying is if I happen to take up 2ft of travel and need more- than I'm going to be worried more about whats going to happen when that suspension settles back down and the rockers/skidplates start dragging. Threre has to be a usefull limit right?
    Twiztid
  17. Donovan
    524
    Arvada, CO
    80blazer I used all the original mounting holes. The cherokee springs are 23" from the front bolt to the center pin. Stock chevy is 23.5". This moves the front axle forward .5". The back of the spring is 28.5 long. I used AutoCad to get the shackel the right length.
    Donovan
    Bigger is Better
  18. 80blazer
    Mar 4, 2001
    41
    glendale arizona
    Thanx Donovan it sounds like a good way to get flexy and good ride and right know I don't have either. Jeff 80Blazer
  19. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I agree that just adding flex doesn't do any good if there is no added stability and/or traction. That is why I would like to see a contact pressure graph. Then, if you see that with X" of droop you had Y lbs of contact pressure before the change but after the change you still have Y lbs with X+6" of droop then you know you have accomplished something positive.
    Bad Dog
  20. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Here is a diagram that Donovan provided which explains sort of what I was talking about a few posts ago.
    Bad Dog
