custom trans tunnel / hump thingy...
Discussion in 'The Garage' started by jekbrown, Nov 27, 2005.
  1. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    I'm going clocked doubler and will have a driveline brake on the back of my np205. This will probably cause some floor clearance issues, even with my 1" of body lift. At any rate, I'd like to fab a custom tunnel, preferably one that had removable panels that might make it easier to install/remove/mess with the trans, t-cases, shift linkages etc. I'm not a sheetmetal guru, so I was thinking of keeping it simple. Run a pair of square or rectangular tubes from the "step" in the tub behind the seats straight foward to the firewall... cut out the stock sheetmetal underneath... bolt/weld some 1" angle to the new edge in the floor directly below the tube so the new sheetmetal panels can all be straight/flat. Add some tabs with nuts welded to the back to allow everything to be bolt-on and viola. I'm sure some people have done this in a stock rig, but most of my searches here or on pir8 tend to show pics of buggies.. which isn't especially helpfull.
    j
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    what year izs your floor? does it have the stock removable piece? if not I'd just find an older set up and run that then do a seperate one for the double access with the same idea you described. just a sheet metal cover with tabs to catch the sides to secure it.
  3. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    '85 tub... its trans cover thing isn't bolted on. If I remember right its spot welded... prolly has some of that nasty-tough factory seam sealer too.
    j
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Its just glued on. Use a heat cun or propane torch to get it off. Takes about 10 min to get it off.
