Customized air cleaner
Discussion in 'The Garage' started by Dafey, Apr 20, 2007.
  1. Dafey
    Dafey 1/2 ton status
    Feb 10, 2007
    2,675
    Roswell NM
    Has anyone customized there stock air cleaner?
    I thought about cutting around mine with my Dremel,to look like a cheap chrome one.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yeah, I drilled a bunch of holes in mine once. No real reason to do it. Just sucking in hot air for the most part.
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I've got the parts I just have to cut it. I'm making a dual snorkle setup and swapping the top and going to a 5" K&N filter. I already knocked out the core support plate and have the nozzel marked out, just need to cut the holes and do some tack welding... :smirk:
  4. dyeager535
    26,979
    I made a dual snorkel setup, didn't make a bit of difference, except possibly louder when I hit the gas.
  5. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
    I was thinking about cutting the sides off mine so it would look like this..
  6. goldwing2000
    goldwing2000 Guest
    Why not just buy one that looks like that? They're only a few dollars if you get a cheapy. Just don't plan on driving through any water or deep mud. Your engine will choke out as soon as the element fills with water.
    If you want to modify your stock air cleaner, modify it with a sealed snorkle tube and run the intake inside the cab or up to the roof line.
  7. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
    I'm not buying one because 1: I'm broke :( 2: I'm bored :p:
    I like your snorkel idea...even if theres no water here. :haha:
    BTW whats the mesh thing inside the filter on my stock assembly?
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Leave that there. It is an "Air Straightener". It is not another filter, it's purpose is to take any turbulent airflow & straighten it out for max flow. It likely also does some muffling of the intake noise too.
    I know, sounds odd.
  9. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    I thought that was just a spark arrestor.... I guess I learn something new everyday.... :eek1:
    ~Brian
  10. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    It is a flame arrester.
    I got 326.7 more Horsesh....Horsepower when I took mine out.:haha:
    Its just glued in with mild strength stuff.
  11. dyeager535
    26,979
    Actually it's an evaporative emissions device. It's filled with charcoal and is supposed to help absorb fuel vapors when the vehicle sits.
    Take it apart and you'll see.
  12. Brians89K5
    Jan 4, 2006
    535
    Rialto Ca.
    Haha my inter net sarcasim isn't so savvy anymore. LoL
  13. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    The one I did remove, violently I might add, was only a series of wire mesh screens. No charcoal or anything else in it. They are very much the same as the air straighteners used in wind tunnels for the same purpose.
  14. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Mine has screens and charcoal.
  15. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
    Right now I'm just going to plug up the heat riser,then buy a hose ,what ever it plugs into at the core support and repair the cold air intake.Then later on when I'm real bored ,fix up something that I could hook up if I ever found water around here :haha:
  16. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    4" clothes dryer flex, Home and Offroad Depot.
  17. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Interesting. Neither of mine do.
  18. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    This is one of my favourite (yes that is spelled correctly...well up here) mysteries here at CK5. Once or twice a year this pops up! :D
  19. dyeager535
    26,979
    I attempted to look it up in the parts manual, and also checked my '86 preliminary service manual.
    Neither one mentions or shows this part, although there is one piece for the air cleaner assemblies (not used in all applications) called a "deflector". I suspect they are talking about the metal piece just inside the snorkle, but there are no pics to show what exactly they are talking about.
    I'm not sure when the usage of that second filter-like device ended, but I know my '83 had it. My parts manual only goes back to '85, so perhaps it wasn't used that late, thus my inability to find anything about it.
  20. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    From the Engineering angle, the deflector keeps the whole assembly from sounding off like an Elephant. My '85 has/had the charcoal element, and I'll look at my parts manual but I blelieve I have seen the words "flame arrestor". :D
