Customized Maintenance checklist??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FWP, Jul 24, 2001.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I started writing my own, and thought- hey, somebody here probably already has one. Does anybody have a comprehensive checklist developed? One where you can record date and miles and check each item as you go. I get tired of forgetting what I did when, even though I save all receipts. The Haynes manual checklist falls short as far as I'm concerned, for example there's no mention of U-joints, or lubing the CV joint center ball on the front driveshaft. I run my K5 on the street and wheel it pretty hard 3- 4 times a month.
    If nobody has a good custom one, I'll keep fooling around with the one I've been working on and send it to whoever can use it.
    Thanks all.
    <a target="_blank" href=http://fwp4x4.rockcrawler.com>fwp4x4.rockcrawler.com</a>
  2. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    Why not just post it here. I know I wouldn't mind seeing it [​IMG]
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Wow, I swear this board is transmitted to my head. I was just thinking I need to develope one of these while I was under my truck swapping the oil pump 2 days ago. I had planned to actually make one on the train tomorrow (right after I package that write-up for you Kevin!), I'll post it when I get to work. Dang, a psychic website...
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **K5 - What more is there to life?**
  4. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Now that would be a helpful tool for all of us !
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
  5. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    how did that oil pump work out for ya?
    You call that dirty!?
  6. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Hey y'all, here's what I did this morning on the way in to work:
    (2 versions on page; had to link directly to the page, site won't allow direct linking to files).
    k5.8m.com/links.htm
    It may not be exactly what was asked for, but it's what I was thinking about the other day so I figured I'd share it. The checklist is an awesome idea, since I'm constantly remembering stuff to check as I'm putting my tools away... That will be tomorrow's commute...
    Oil pump worked out awesome, Mike!! I thought my guage was going to pop when I started the thing! It now sits at about 20PSI hot, in gear, at idle, and like 60 at 2000 rpm! Not like the old one that sat at zero in less harsh conditions... I'm going to do the bearings anyway, just because the pan was so incredibly easy to take off, and looking at it, looks like a cakewalk job.
    Ratch
  7. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Looks great! I'll try and get a fire apparatus maintenance card scanned/copied to pilfer ideas from too.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  8. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I can't seem to get that to work. I get an "access forbidden or authentication not supported" error when clicking either the DOC or PDF link. Can you email it to me at bglass@flexjet.com?
    Thanks!
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
  9. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Brian, I emailed the link and both files directly to you.
    Just added a feedback link to the page too, all.
    Ratch
  10. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Pretty good start so far, thanks. I'll keep workin on mine, wanting to get some more detail. I hate forgetting stuff[​IMG]
  11. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    I've been working on 2 different ones. One quick one I did was in Microsoft Excel. The one I'm semi-working on will be Access based. It will open with a page listing all your vehicles. From there you go to "add a new record" "record a service" etc.. It will have a place to put milage, where parts were purchased from, warranty that may be applicable &amp; when it expires, price paid for part... You know, all the good stuff. Plus, I hope when its all done, you will beable to run a query on each vehicle and tell what all you had spent money on, types of parts, how much money, how often it failed. Help to identify problem parts &amp; stuff to carry with you.
    Later guys,
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    <a target="_blank" href=http://www.geocities.com/corey_perez>http://www.geocities.com/corey_perez</a>
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Have you checked any of the shareware sites for existing stuff? Just clicking on the first couple of links from a search on "auto maintenance" and shareware at http://www.downlinx.com/proghtml/142/14242.htm
  13. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I have 5 lists that I use regularly. One is a checklist for load-up kit, one is a pre-trail list, one is a post-trail, one is 2x per year list. My other maintenance record consists of every section of the truck (front diff, rear diff, t-case, engine etc) broken down into all the different parts (wheel bearings, brake pads, balljoints, oil change, grease etc) with listings for date, mileage, price, part #, notes etc. I included the part numbers because I got tired of trying to remember the different years, and specifics of all the donor vehicles making up my truck, I just call and ask for part #... whatever. If you want, I can email a sample to ya.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
  14. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    hey, if you could post one or email it, that'd be great!
    Ratch
  15. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Yeah that sounds very usefull.
    Stuck? Isn't that a bird!
    Steve
  16. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Hey numbnuts...saturday my shop has an open scedule....if you want we can address the a/c in the 75...and i forgot...i have a box of goodies i got off ebay i thought i might need when i did the TBI swap....comp core (R4)....and brackets..lines for a/c on a 85 K5....you've got the evap box on the 77...so i think we can do old yeller up also!
    Let me know before i go and make plans...which i doubt as we are meeting at 7am sunday to venture out to the Table Mesa trails....and i got alot i could do with the 79...lol..which btw has frosty air as of last night..hehehe.
    Azblazer
    1979 K5 350 TBI
    1976 K5 Chalet
    If it ain't got arizona pinstriping.....you ain't wheelin the pee outa her!
