Cut Fenders or Bushwacker Cutouts?
Discussion in 'The Garage' started by coptezr, Mar 31, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    i dont know what to do i need some help.. my balzer is grey with black rino liner on the bottom and i plan on putting some 36's that are wider so it will fill the fenders out more.. i just cant decide what way to go? :confused:
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Just cut them!!! It's way cheaper :hack: :hack: :hack:
  3. coptezr
    Jan 13, 2005
    342
    how nice is it going to look if i do it that way?
  4. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
  5. coptezr
    Jan 13, 2005
    342
    yea it looks ok but i like the look of the cutouts well how mu more tire space can get with cuting them then getting cutouts?
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Nicer than if you bash the cutouts against a rock or tree. Ask me how I know this :blush:
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    cut the fenders. i dont care for the fender flares. if you do it right it can turn out really good.
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Well all I can say is that I HAD to have fender flares to get the truck through inspection....
    Personally I like the cutout flares... althought they dont give much cut though... fronts get 2" I think it was... 1" on each side and the back was allowed 4"... 2" front and 2" back... although I recentered my axle this way... just moved the wheel well.... went 4" in front of tire !!!!!
    all I know is when I goto bloomsburg this year I am planning on leaving without a ticket (make a quick fab for my mudflaps and cut them down in size a bit first)
    http://rootbreaker.no-ip.com/PROJECT_NJLEGAL/5_16_2004/bushwacker.htm
    but I am going to put zero rates on the front.. move axle forward 1"... take flares off..go offroad and flex the truck... bring my sawzaw and cut till I am happy.. then try and figure out how to put the flares back on and cut them so they dont look bad
  9. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    if you are ever going to wheel the rig, dont use cut outs. One good bash and they are toast. If you are so worried about the bling of a fender trim job, take it to a body shop and have them do it... they can give you a factory-like rolled edge etc if you really care... if you brought them the fender removed from the rig, the final price would prolly be less than a full set of bushwacker flares...
    j
  10. coptezr
    Jan 13, 2005
    342
    any more pics?
  11. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Yup, me too! On my old 76, I just cut the fenders out. But that only had 40's on it. They didn't stick out as far as my 44's do. I know part of it is the 14" wide rims there on. The next rims will be 12's. or 10's with beadlocks.
    My 73 has the bushwakers cut outs on them. They look decent, but they do break easy. I have glued mine a couple times. They really don't clear my 44's when stuffed. The flares are only 40" wide. They hit in the front since I moved the axel foward.
