Cut my KNUCKLES??
Discussion in 'The Garage' started by owen, Feb 11, 2005.
  1. owen
    owen 1/2 ton status
    Nov 21, 2003
    151
    Brewton AL
    Just got my hi-steer on and wanted to know if it would be safe to cut/grind the old rod-end armie things off of the knuckles. I dont know much about the effects of heat or the process of casting iron. Will this compromise the strength of the knuckles?
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    use a saw-zall or band saw & u will be fine, i would use a flap wheel on a 4.5" angle grinder to sllick it up
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    DON'T use a torch - as stated, bandsaw or sawzall will be good for the cut, and the flapwheel on a grinder to clean up the rough edges when done.
