Cut off year for Smog check in AZ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by StonerK5, Feb 15, 2002.
  1. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    I was looking for the years that are smog exempt in Arizona
    Thought it was 78, but not too sure
    "What ever happened to my Rock N Roll?"
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The e test cuttoff is 68 I think. I think 78 is for cats, but I am not sure.
    My Chevy isn't broken, its just out of gas.
  3. StonerK5
    Feb 13, 2002
    183
    Phoenix Arizona
    Thanks, that must of been what I was thinking
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    In that case, I need to find a pre-78 cab so that I can get my K30 titled and smogged without cats. Anyone in AZ got a cab? Don't care much about the condition. Maybe even an older model so I don't have to worry at all...
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I think 1 tons were excempt for a couple more years, but I am not for sure on that. But I think once the GVW went past a certain point they got exempted for a few more years, but you might want to call and find out for sure.
  6. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    In the greater phoenix area (Maricopa County) 67 and newer need emissions.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I was close. I thought it was 68 because I thought my buddies 67 Chevelle, didn't need emissions, but it must have been his 66 Chevy pickup.
  8. NoRulz
    NoRulz 1/2 ton status
    Feb 6, 2001
    388
    Mesa, AZ
    BadDog, most 1 tons don't need cats up 'till 86 I belive
    My Ford has chevy parts! it's all good!
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Mine is an '85 so I guess I should look further into it. All I know is I don't ever want to tow it on a trailer down 40 odd miles of fire roads again. [​IMG] I wonder how that applies with and 89 TBI 350?
    Russ
  10. NoRulz
    Feb 6, 2001
    388
    Mesa, AZ
    I don't know the law for sure, but they don't really care what's in there for an engine. As long as it passes the sniffer, &amp; has the equipment required for an 85, you should be ok. Only thing you might have problems with is I assume you pulled the vapor recovery stuff off if it even had it? Otherwise I'd assume you still have EGR, should be much more than that.
    Worst case you go down there &amp; have it tested, &amp; see what they say you need.
