Cut-out flares
Discussion in 'The Garage' started by DragonsBane, Aug 2, 2006.
  1. DragonsBane
    DragonsBane Registered Member
    Dec 28, 2005
    47
    Clifton, AZ
    do you have to cut out above the wheel well when installing or is it just the front and back of the wheel well? Like I said in another post I have some body rot starting. If I can cut it off now it would be better. I need about 2 inches above the rear wheel to get it all off. Or would I have to go with a custon flare? Maybe soms lawn edging?
  2. KADILLACKID
    KADILLACKID Registered Member
    Jul 2, 2006
    35
    Toronto north,Canada
    You cut everything.....not sure about these trucks but I put a set on my 92 and they cut 2" all the way around i believe.....then the flares are at least a few inches tall,so,id say they cover at least 4-6" above and around the wheelwell opening....Very good for covering rust!!!
  3. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    on my truck you only cut front and back.. not the top... there are screws that actually screw into the top part... :crazy:
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Correct you are. I am putting some on now. The top edge is needed to secure the flare. I suppose that you could cut it and bend a new lip, but you would have to even it out by cutting the bottom also.
  5. RootBreaker
    Nov 29, 2001
    5,118
    173
    so since I told your wife that you got them off of ebay for $100....
    PICS!!!!! :haha:
  6. cbbr
    Jul 17, 2004
    14,681
    Soon. I actuall did get them for $100 and shipping, but The gimps (rubber gasket thingys) were missing. Trailtoyz has a set coming my way, which is really cool of him since its a low buck weird part.
  7. RootBreaker
    Nov 29, 2001
    5,118
    173
    dayum!!! I paid $365 new to my door from summit
  8. cbbr
    Jul 17, 2004
    14,681
    Which is not a bad deal. Mine needed a little cleanup, but I will have about $150 in them.
