cut the frame or move the hangers????????????????
Discussion in 'The Garage' started by TWISTEDJACK, Jul 31, 2003.
  1. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I am getting ready to start my flatbed/shorten the wheelbase project. I am torn between cuting the frame or moving the spring hangers. My wheelbase is 133 right now, I am shooting for 115-120. I have see it done both ways. The issues that I see with moving the hangers is figuring out the pinion angles. /forums/images/graemlins/confused.gif The problems I see with cutting the frame is cracking later. /forums/images/graemlins/confused.gif If I cut the frame a friend of mine that extends/shortens truck frames is going to weld it up. He said it should be fine as long as the frame is allowed to twist.
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    If you cut the frame with a step in it, reweld and re-inforce the area it will be fine. I have seen that method used with heavily abused dump trucks to extend the frame with good results.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    cut the frame. Moving both hangers would just be a hassle.
    will the vehcile be driven on the street?
  4. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    I was told to cut it on an angle at 2 1/2 times the height of the frame and not to reinforce. So if the frame is 10" high I would cut on an angle 25" and then reweld.
    And yes I do drive it on the street still.
  5. kennyw
    Jun 9, 2002
    13,223
    94
    Frame splicing article
    I would not do any kind of splice without re-inforcement /forums/images/graemlins/eek.gif
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if you plate the frame behind the cut you do not even need to weld it.
    look at the 3 piece dodge frames, 3 subsections riveted together.
    my money is that you will have ZERO issues with cutting and welding your frame,
    angles/steps/vertical not real important
    I would have a piece of steel formed to fit inside the rail and bolt it in place, but IMO it is just for piece of mind
