cutting a notch in the crossmember or useing a tcase loweing kit?
Discussion in 'The Garage' started by spongeidys, Oct 10, 2005.
  1. spongeidys
    spongeidys 1/2 ton status
    Jul 6, 2005
    2,566
    Dillion, CO and Palmerton, PA
    would it be smarter to cut a notch in the crossmember so the front driveshaft does not come in contact with it or get a tcase lowering kit?
    as it sits right now the front driveshaft is rubbing aginst the crossmember
    would like some imput on which would be better in the long run ;D
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I have a lowering kit and am going to be getting rid of it at the earliest opportunity. It actually makes the angle for the front shaft worse because it's tilting the entire drivetrain.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I take it you have the tall style adapter for the 208?? You have 2 choices. Either get the short adapter and the "W" shaped crossmemeber or 4wp sells a spacer for like 40-50 that will make it clear.
  4. spongeidys
    Jul 6, 2005
    2,566
    thats why i came here and asked cause i learned on here the lowering kits make the angle for the front harder to acheive ;D ill check into one of those spacers
  5. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
    I have a lowered crossmember using the factory spacers at the frame to lower it an inch, but then I had spacers machined to raise the tranny/t-case back up an inch under the adapter so now I have an extra inch of clearance between the driveshaft and the crossmember.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if the front driveshaft is rubbing the crossmember, unless you have alot of lift, there is something wrong. IE wore tcase mounts, bent crossmember, or like mine, a broken tcase mount foot.
    check those before you spend any money on something that will only fix the problem half way.
  7. spongeidys
    Jul 6, 2005
    2,566
    running 8" of lift ;o but i will check those just incase ;D
