cutting body lift pucks in half
Discussion in 'The Garage' started by MNorby, Nov 27, 2006.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I want to take my 3" BL pucks and cut in half into 1.5"ers. I tried a sawzall and ended up butchering one pretty bad. Not enough to clamp into the band saw or chop saw either. Thought about bolting 2 pucks together then using band saw and just rotate a couple times so I don't cut through bolt and loose it. Any other ideas that I'm not thinking of?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Cant just free hand it on the band saw??
  3. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    could but its the type that falls down on its own, not really a upright. I have used it upright before but it has a small base then (like 1"x1") which is really just the gaurd.
  4. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Slap in a vise and cut off wheel?
  5. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    :eek1: when I was 19 and first went truggy I used a sawzall and my hand to hold it..worke fine
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Hacksaw & a vise. I made my 3" body lift into a 2". ;)
  7. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    well, I bolted 2 pucks together and used our big band saw, works pretty good. Cut till I hit bolt the rotated some. Thanks guys
  8. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    if you look at the blocks there cast 180 off from the other half for strength. if you need 1.5 lift best get some aluminum or steel blocks made for the job. i wouldnt feel same running them my self like that.
  9. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I plan on doing this to level out my bed because I have about a 2.5 body lift on the cab and a full 3" on the bed.
  10. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    If you cut dead center it makes a full top too though with just holes not wide open. I'm not too worried about it. I got it all on tonight (can see pics in the 69-72 board)
  11. 85-m1028
    85-m1028 1/2 ton status
    Apr 26, 2005
    485
    costa mesa california
    little late but I was gonna say clamp it between two blocks of wood on a chop saw....
