Cutting Brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan Melton, May 6, 2001.
  1. Ryan Melton
    Ryan Melton Registered Member
    Dec 15, 2000
    61
    Texas
    Any one here running cutting brakes in their rig? The Currie's "Fire Ant" Jeep is running them along with other rockcrawlers. I plan on running them in my truck with an ARB in the rear and wanted everyone's opinion / experiences with them. Also does anyone know what brand most of the rockcrawlers use? I think some are manufactured by NEAL, but I'm not familar with this company. Do they just plumb into dual rear lines? Thanks for the help.
    Ryan
  2. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    What are cutting brakes?? (apart from what you do to someone when your pissed off at 'em)
    Why do people keep calling it a Bronco!!!!! [​IMG]
  3. Ryan Melton
    Dec 15, 2000
    61
    Texas
    You can lock up one of you rear wheels, put your T-Case in front wheel drive and it allows you to pivot off of the locked wheel. The other rear wheel will just roll and the front will spin the veh around. Best done on loose ground with big axles.
  4. CV202
    Nov 14, 2000
    454
    Kingfield, ME
    Sweet, kinda like a skidsteer. Never thought of doin it with a truck. Sure you could adapt some line locks....
  5. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    Like Ryan said the key too doing this is being able too front wheel drive the transfer case.Too let the front tires pull around one of the locked up whels in back.And you could use cutting brakes from any of the sand buggy places.they have two levers that you plumb in too each side.
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    How about useing some kind of independent "E-brake" cables/handles?
    My best example of useing a cutter brake was; I backed the rear bumper into the mountain, cranked the front tires, and gave it some throtle in reverse with the R.R. bumper wedged up against the mountain, that swung my front end around and I was able to go back the way I came. Not realy a cutter brake but it worked and I could see a definite advantage to have some kind of independent rear brakeing ability.
    Twiztid
  7. shane
    shane 1/2 ton status
    May 6, 2001
    162
    Prince George, BC, Canada
    You could set up seperate hand levers for each of your ememergency brakes. Should do what you want.
    Just keepin it Canadian[​IMG]
  8. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    that is what i have planned, but have been to busy on other more important stuff...i have an old 14 bolt with the e-brake cables that are each the same length, my plan is to take 2 handles off a small car and hook one up to each rear drum. as far as mounting them, i think there is enough room to the left of my t-case handle, and since i have a body lift, under neath clearance isnt an issue......still on the drawing boards.....
    AIRBORNE!!
