Cutting Break
Discussion in 'The Garage' started by 79Stomper, Aug 18, 2004.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I have seen a few posts and read some articles that mention a cutting break but can somone explain this to me? Or maybe a few possible links where I can do some research on the subject.
    TIS /forums/images/graemlins/waytogo.gif
    James
  2. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    Cutting brakes are used for sharp turns. Let say if you engage(lock) left rear brake & drive thru(apply power) the turn on your right rear. It will pivot on the left rear tire. This will only work if you have a Detriot or simuliar locker that will unlock or open diff. NO SPOOLs or WELDED. This also helps an open diff if you have 1 wheel spinning, apply brake to that wheel, it transfer some bias to the non spinning wheel. In essense a poor man's locker. Hope this helps you understand it alittle better. /forums/images/graemlins/usaflag.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Atlas is a good case for cutting brakes cause you can disengage the rear drive and just have front. an ARB is another good option for cutting brakes.
  4. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    All right I get the concept but how does one go about making one side of the axle brake and the other freely rotate?
  5. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    you have to run a seperate brake line for each side, then have it operated by a lever of some type, when you want to lock one wheel you pull that lever and the brake is applyed to only one tire and the other three can drive
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Line locks work good for this kind of stuff.
  7. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    You can purchase smaller master cyl. to plumb in line to use as cutting brakes. I know RockBuggySupply used to carry them.
  8. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    I have them on my Blazer. You can see the pics in my webshots. http://community.webshots.com/user/rjdinkins
    I do not use them real often, but they definitely come in handy when you want to make a tight turn. I dis-engage the rear axle, lock one side and drive around on the front axle only. I also have detroits in both ends and the cutting brakes still work fine.
    Russ
