cutting fenders ya or na?
Discussion in 'The Garage' started by coptezr, Apr 2, 2005.
Cut fenders or Cut-Outs?
  1. Bushwacker Cut-Outs
    10.9%
  2. Just cut em
    89.8%
Multiple votes are allowed.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    should i cut the fenders or bushwacker cut outs? ow much more can i cut with out the cut outs and i have 35's with a sex inch lift. will i have enough clearance for 36's
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    i only have 6in wish i had sex''in lift. im putin on 38''s.u should easily put on 36''.
  3. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    there are alot of questions that need to be asked to help you out specifically, although if you look in yesterdays posts you could find a few topics with the exact same question.
    mall crawler
    If you dont do much wheeling and its a big bling bling truck, you can get away with just cutting the edges off the front fenders and no one will know the diffrence. this is what i did at first with my 36s, but i only had a 4 inch lift.
    wheeler
    If you do abunch of flexy stuff and your tires willl be thrashed into your sheet metal, i would deffinately trim a litte bit. currently i am running 7 inches of lift and i only did some minor trimming and i can get a decent flex. i even considerd bushwacker cutouts. but with the thousands of threads on ck5 with the question repeditaly asked, bushwacker cutouts, yey or ney, you will find alot of neys.
    1. they break easy (someone said they broke one on a trash can coming out of a driveway)
    2. they are expensive
    3. IMO a clean fender trim that will cost you near to nothing will look better then getting bulky grey, expensive pieces of plastc.
    John
  4. coptezr
    Jan 13, 2005
    342
    ok ok you guy got me send me some pic with the fenders cut cause thats what im doing sunday then :D
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    :hack: :hack: :hack: is the only way!
  6. coptezr
    Jan 13, 2005
    342
    pics pics pics
    :o
  7. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    rears not done, obviously
  8. highlow
    highlow 1/2 ton status
    Oct 8, 2002
    124
    4" lift rear 5 1/2 lift in front and 36x12.5x15 swampers and cut fenders, it works :D
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    35s with a 6" lift should clear just fine, you may have to trim the bottom rear of the front fenders, it may run while turning at full stuff
    i have a 4" lift and 35s, and i had to cut the bottom corner off the front fenders to keep it from rubbing.
  10. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    36's will rub... My 35's won't unless i'm flexed all the way out and turned all the way, because of my silveradoe chrome trim... it got balled up in the wheel well and started to rub.
    Only reason i would go with bushwackers is the fact it lets you run an offset rim and a wider tire.
  11. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Cut fender's look waayyyyy better anyway's! You wanna be cool,cut your sheit! :p:
  12. coptezr
    Jan 13, 2005
    342
    :saweet: ok ok ok ok ill do it :D
  13. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    5" of lift and 39.5's...
    Just trim them...
    Rene
  14. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    I cut mine, and then welded in 1/4" rod bent (nominally bent, anyway) to fit.
    Given the chance to do it over again, I'd use smaller welding wire, and find someone who groks sheetmetal. I *suck* at welding sheetmetal :D
    Still, it came out okay, and doesn't look any worse than the rest of the truck.
    In this pic, it's 33"'s on 4" lift (4" Ranchos up front and shackle flip in back) ... it has 35"'s on it now, but no good pix :(
    -- A
  15. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    No tailgate? :)
    Rene
  16. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    37x12.5x15 MTRs on 8" wide wheels. I only have a 2.5" lift, and in this pic you can see what happens with no cutting.
    And I don't think the suspension is fully compressed, but close.
  17. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    LOL.... the pole speaks for itself.
  18. coptezr
    Jan 13, 2005
    342
    yes it does :D
  19. dremu
    Feb 27, 2000
    15,968
    461
    I'm getting there ... it's a work in progress:
    -- A
  20. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Ain't need no stinkin' fenders...
