Cutting floor for Body Mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by walt88, Jul 25, 2001.
  1. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    Hello, is there ANY way to not cut holes in the floor to get to the body mounts? The first 2 are obvioulsy accessable. But the rest are under the body. Anyone who has done this please give me some info. Thanks
    1988 K5- Piss on Ford/Dodge/Jeep
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    If I remember right, the rest are threaded from the bottom up - except for the two above the rear axle which are just under the rug.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I don't know YET. My front cab mounts have rusted and stripped out, (the welded nut inside, broke loose and just spun, so I cut the bolt) Sooner or later I'll have to tackle this and would also like some pointers, if some one has been down that road, drop us a line please.
    Twiztid
    Edited; Um, probably should have read the FULL question first!
    Walt88, no fear. Normaly, the bolts are exceible (s/p?) from under the body, Nuts or bolts. Usualy not a problem. I think in my case, the floor was rusted out, and the 1/2 impact gun on the rusted bolt didn't help out.- so don't use one of those -K-<P ID="edit"><FONT class="small">Edited by Twiztid on 07/25/01 10:15 PM.</FONT></P>
