Cutting Magnesium Run-Flats with Plasma?
Discussion in 'The Garage' started by jeffro, Jan 3, 2004.
  1. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Is it safe or will ir blow up in my face. They aren't 100% magnesium are they?
    Thanks in advance,
    Jeff
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Personaly I would never put any type of fire to magnesium. Once it starts to burn look out /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif Never ever put water on magnesium when it is burning either /forums/images/graemlins/eek.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/eek.gif We've looked in to turning some parts at work that are made out of magnesium, after about an hour of research, we put the blue prints in the trash /forums/images/graemlins/deal.gif Good luck
  3. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    I read the best/safest method was a ban saw or sawzall with a 10 tpi blade.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Magnesium burns white hot when ignited and you can't put it out with hardly anything. I wouldn't get anywhere near it with a plasma cutter. /forums/images/graemlins/eek.gif
  5. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    magnesium is COOL when it burns. If it starts going out poor some water on it and itll come back to life. Really neat stuff in small amounts
    nick
  6. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I had this magnesium block, it was a fire starter. The stuff burns very bright and very hot. LOOK OUT /forums/images/graemlins/angryfire.gif
  7. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    We just had a whole Magnesium Recycling plant burn to the ground here.Fire burned for two days. Millions in damage
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if you do it, call the FD first, set up a LOT of video cameras, and dont do it near your house!!
    bandsaw or similar ONLY. mag starts and there is only a few ways to put it out. sand works well, but it just encapsulates itself in the newly formed glass. a few other high dollar things out there do it as well. but they are glorified sand.
    good luck, and like i said, if you do do it then i want a video of it.
    Grant
  9. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    I SAW that fire from Cuyahoga Heights where I work! The whole damn SKY lit up!! Saw it even better driving home on I-480...people were almost driving off the roads gawking.
  10. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    if you cut it withanything have something with witch to put it out. sand will work but make sure it is dry dry dry dry. water ill make it explode, if you can find an extinguisher or sand like stuff it must be rated for a class D fire the d will have a star around it. try a meachen shop they might have some if the work with, magnesium, or alumanium /forums/images/graemlins/angryfire.gif1 be carefull, with the saw so as not to heat it up and don't use plasma enuff heat and it will take off on you.
  11. 72beater
    72beater 1/2 ton status
    Oct 11, 2002
    224
    Nation\'s Capital
    have someone you don't like do it, it will be quite a show!
  12. unick
    Aug 16, 2003
    4,286
    HAHAHAHA
  13. unick
    Aug 16, 2003
    4,286
    HAHAHAHA now thats funny
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Isn't magnesium really hard to start on fire? I know that once it starts it won't stop, and I wouldn't take a chance with the plasma cutter, but isn't it damn near impossible to get it going?
  15. unick
    Aug 16, 2003
    4,286
    we through a block of it in a camp fire once and it caught takes alot though. Buddys a fire fighter and said that mag needs like 1400 deg b4 it will ignight
