cutting off tail pipes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chris672, Mar 23, 2002.
  1. chris672
    chris672 1/2 ton status
    Jan 25, 2002
    554
    LODI, CA
    My Jimmy as a flowmaster with dual output and the tail pipes go to the back of the truck and out the sides. One pipe comes out about 8 inchs lower than the other. Can I just cut off the tail pipes after the muffler? Should I put on some turn downs?
    thanks
  2. 73BlazerT
    73BlazerT Registered Member
    Mar 18, 2002
    26
    Jefferson City, Missouri
    Not sure what the laws are there but here in Missouri the exhaust HAS to exit the vehicle.
  3. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    Did the same thing but didn't want to spend the extra money. Due to the fact looking ahead at a Big Block this year. When the Big Block goes in I will definitely put in a completed exhaust system. The fumes are killer, especially with the little one in the back seat..
    Eat More Mud!!!
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you cut the pipes off at the mufflers you will get a lot of exahust fumes in the cab. Fumes get sucked in thru the tailgate as you drive down the road. Its bad.
    Running the exahust out the side is the only way to go oin a K5
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    We have turn downs just before the rear end on the '81 and '89 and never sucked fumes before. Sure did though before the new setup was put on the '81. Cough Cough, it wasn't fun. I havent noticed anything with the turndowns though.
  6. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    Chris you can cut your tail pipes and put the turn downs on it will look and sound good. It's good to see someone else from lodi on here maybe one we can meet some time. Later <font color=red> 1 FN HI K5 <font color=red>
    <font color=blue> Clicky below to see picks <font color=blue>
