Cutting off the Hitch???
Discussion in 'The Garage' started by fwc, Oct 18, 2004.
  1. fwc
    fwc Registered Member Premium Member
    Nov 2, 2003
    84
    Northern Virginia
    Anything I need to consider before I /forums/images/graemlins/hack.gif off my trailer hitch? Do I need to add back a piece of steel to reinforce or tie together the rearmost part of the frame?
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I don't think so. I think they were an option anyways so some didn't even have em. I think, help me out here guys.
  3. fwc
    Nov 2, 2003
    84
    Northern Virginia
    The hitch is fairly well rusted on so I was just going to grind off the bolts and take a BFH to it. Even if the hitches were optional, would it still be a good idea to weld a cross bar on the end of the frame?
  4. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    You can;t just unbolt it ?
    I boxed the rear of my frame with a hitch between the spring hangers......... so i guess you'd HAVE to cut out something like that?
    I'm not too familiar with what you have so....
  5. fwc
    Nov 2, 2003
    84
    Northern Virginia
    Stock 91 Jimmy. Its pretty rusted so I am not going to spend too much time with the wrench if the bolts arent turning. All the better if it unbolts easily.
  6. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Drill or torch the bolts if you can
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    you shouldnt have to have a crossmember there.hitches are an option and many trucks came without them. the frame might benifit from a hitch/crossmember in the back, but definatly not nessesary.
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    The bolts are only a couple of inches from the gas tank /forums/images/graemlins/weld.gif /forums/images/graemlins/yikes.gif
  9. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Not a problem unless the tank leaks /forums/images/graemlins/whistling.gif
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    mine didnt come with a "hitch" it just has that stupid thing with the ball that attaches to the bumper and then to the frame..........I think im going to take it off.
    your hitch should just bolt to the bottom of the frame so if the bolts are stuck just use some penetrating oil and a long braker bar, they should not be to difficult. I wouldnt use a torch that close to the gas tank, there might be fumes around it that could ignite /forums/images/graemlins/thumb.gif
  11. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    Sometimes it is easier to just tighten and snap the bolts then to fight with the rust all the way off.
  12. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    You've lived down south too long my friend...
    /forums/images/graemlins/screwy.gif
    I'de day use an air chisel /forums/images/graemlins/waytogo.gif
  13. blueblaze
    blueblaze 1/2 ton status
    Dec 4, 2001
    274
    Salt Lake City, UT
    /forums/images/graemlins/doah.gif
  14. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    the one on my sub is welded on humm.
    and if it is as rusty as that pic just tie it to a big tree and drop the hammer! /forums/images/graemlins/waytogo.gif
