cutting oil
Discussion in 'The Garage' started by yunit, Oct 8, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Where can I order some good cutting oil for tapping? Thanks, Pete.
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Check any local Indusrial supply company.
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    If you are tapping mild steel, almost any oil will work. WD 40, Marvel, heck even motor oil will work. If you are tapping something like tool steel or stainless, then by all means get some cutting oil. My .02
    John
  4. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    Try Home Depot or Lowes first. Otherwise, I would try Grainger or McMaster-Carr. They are both have web sites & NJ locations but can be expensive on things.
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    any good Hardware store should have it
  6. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Kerosene will work sweet on aluminum, probably satisfactory on other metals too. /forums/images/graemlins/thumb.gif
  7. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    we use gear oil with good results on just about everything....
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    The best stuff there is Rapid Tap. It's in a little yellow can.. You can buy it at home depot. Or most Hardware stores... /forums/images/graemlins/thumb.gif
  9. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    The best stuff I have found is called Tap Magic. There used to be a formula for aluminum and a different one for steel and cast iron but the last time I bought it they must have reformulated it because now one kind does all materials, and it still works just as good. Like said above, try your local hardware store.
