Cutting out OEM gauges, replace with AM
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by HarryL, Jun 7, 2001.
  1. HarryL
    HarryL 1/2 ton status
    Feb 25, 2001
    139
    Layton, UT (20 miles north of SLC)
    Howdy.
    Has anyone removed the OEM gauges from the stock bezel and replaced them with Aftermarket gauges?
    I have 2 or 3 spare instrument panels, and have taken one apart to get an idea of what is involved. before I start cutting, I'd like your experiences. Tools, gauge size, manufacturer, dimensions, etc.
    Steve Chin: didn't you stick a speedo from a LM camaro in yours? How did you go about installing it?
    Harry
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I have a late model Camaro tachometer in my gauge cluster. It involved a lot of cutting, bending, drilling, and soldering to make it work. It mounts like the OEM gauges to the back panel of the gauge cluster. A set of aftermarket gauges would mount differently. I was going to change out the mechanical oil pressure gauge for an electric one, but I've put that on the back burner. It's going to require cutting the gauge out of its little capsule snd fabricating brackets to mount it to the OEM back panel so that I get a more-or-less OEM look to the install. I'm also planning that kind of install with a mixture gauge (also on the back burner).
  3. 72lowblazer
    72lowblazer Registered Member
    Mar 8, 2001
    10
    Annville, PA
    here is a link that has some picts for you. <A target="_blank" HREF=http://67-72chevytrucks.com/board/ubbhtml/Forum1/HTML/007138.html>http://67-72chevytrucks.com/board/ubbhtml/Forum1/HTML/007138.html</A>
    72 k5 Blazer 307/3pd on tree, posi rear (one of my projects
    69 Chevy Pickup currently being put together
  4. BluThndr71JMMY
    BluThndr71JMMY 1/2 ton status
    May 12, 2000
    152
    Tucson, AZ
    Whatever you do, DON'T wash that dusty lens with any kind of harsh soap. I wiped out the lettering on a junkyard test dash trying that.
  5. kilomanjaro
    kilomanjaro 1/2 ton status
    Feb 22, 2000
    229
    Manhattan, Ks USA
    I was thinking about putting aftermarket guages in my truck, but after seeing alot of peoples attempts i am just going to spring for the stock look. More power to you if you can make it look original, but most of the ones i have seen do not. just another question kind of off topic, on a factory tach, where does the factory wiring harness for it hook up? Coil? sorry just had to ask. thanks
  6. Steve_Chin
    Mar 6, 2001
    1,126
    All factory tachs have three wiring connections: Negative side of the coil, ignition switched 12V, and ground (some ground through the instrument cluster).
