cutting out
Discussion in 'The Garage' started by mostwanted, Oct 16, 2006.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    As I was driving down to my folks' house yesterday, my motor started cutting out. I believe that it is an ignition problem. It almost sounds like a backfire popping sound under acceleration. When I pulled over to inspect my plug wires and cap, I didn't see anything that stood out as being the culprit. I was thinking of replaceing the D-cap and coil. Any ideas?
  2. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Mine does this intermitantly. once it is warm, it cuts out while gas pedal is pressed, but if i let off and coast it doesnt do it...a couple minutes later it does it again.
    Im going to replace the ignition module and see what happens. Im very dumbfounded on what to do.
  3. Habez
    Habez Registered Member
    Mar 27, 2003
    45
    Houghton/Frankenmuth, MI
    mine did something much like it. It cut out under high acceleration, then it started happening more often. The guys at the parts stores said it must have been my plugs or ignition. It ended up being my fuel pump.
  4. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    I have had some troubles with my fuel pump in the past but it acted a little diffrently. It sounded like vrrrrrrrrrrrrrPOPvrrrrrrrrrrrrrPOPvrrrrrrrrrrr! If that makes any sense. When it was the fuel pump it would studder like it was going to run out of gas and shut off. I hate to say it but it sounds like detonation. I am going to go pull some spark plugs.
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    When this happened to me,it was a cracked valve :(
    But it could be a host of things (ign, fuel pump, timing,..etc). Cracked valve can be easily found with a compression check.
  6. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    prolly plugs and wires.
