Cutting spring perches and shock mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CaptCrunch, Dec 20, 2001.
  1. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    thinking about having a buddy do it. Any tips? Do you recomend reusing the shock mounts and perches or get new ones. If new who did you get them from? How much? Part number? thanks
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    For the shock mounts either reuse them or build new ones. And for the Perches, just get new ones! You can get them at Summit Racing for about $12 -$20 ea. Or any driveline shop should carry them!
    Also, when cutting that stuff off be extremely careful not to burn into the axle tubes much if you are using torches!
    Mike
    <font color=green>"My K5 is purdyur than your sister!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I used a grinder to cut the welds and a bfh to help get them off. I reused the spring perchs on mine. For the shock mounts I cut a set off a junk 10 bolt and used them on the 14ff. The shock mounts are just temp. untill I do the long shock conversion.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Spring perches? If I needed to move a pair, <a target="_blank" href=http://www.off-road.com/chevy/tech/perch/>this</a> is what I would do.
    Not sure about the shock mounts. Mine hang down and need to be moved. If you find a super cool solution, be sure to let me know. [​IMG]
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  5. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    If you're careful, you can reuse them. I used a grinder to remove the perches and used a torch to remove the shock mounts. I reused my perches, but not the shock mounts.
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  6. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Thanks guys.... I appriciate the info... I'm working with a couple different guys... one that does this sometimes in his driveline business, but definetly wanted to see how some of the 4 wheelers do it. My buddy Tim does 4 wheeling, but he has a jeep [​IMG] [​IMG] LOL.
    -Mikey
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Mikey, I did the R&amp;R on Rocko's 14FF we traded.
    That rear was a true 1 ton rear and I used a 4" grinder til the perches came off. I also used a BFH to break them loose.
    Then used a stick welder, but can't remember what size rods they were. [​IMG] I welded a little at a time to allow for cooling so the tubes would not get warped.
    The shock mounts were done easily, too. Ground them off and used the same welder, too.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  8. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    ORU sells some thick replacement perches for 24 bux.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have their catalog and they list them as "3/16 inch" thick.
    The stamped-steel perches on my '85 are something like 3/8 inch thick!! [​IMG]
    I would prefer to find some thicker perches like the factory ones on the '85 and newer 14FF's.
    Anybody know how to get some perches from GM like these massive ones on these rears?
  10. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    So just be careful not to warp the tubes... got it. I won't be doing the welding cause I really don't have much experience or equipment, but both the buds are licensed so they should know their stuff.
    -Mikey
