cutting the body up, what works the best.
Discussion in 'The Garage' started by big83chevy4x4, May 16, 2003.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i can get an air nibbler, air sheer, cutoff wheel, or a sawzall. im going to do some rust repair and some fender trimming, what should i go with, what would give me the best results?
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Probably a combination of all the tool's You mentioned, how about a Plasma Cutter? Have access to one of those? It'll come in handy. /forums/images/graemlins/grin.gif
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Jigsaw! I just did SICK trimming on mine not too long ago to fit 42's. I was VERY pleased with the clean cut. You can even make turns with ease. I used sheet metal blades. Just changed to a new one after each fender to keep the blade sharp (reduces the vibrations when cutting.)
    Good luck!
    -Dan
  4. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    I did all my trimming with a craftsman sawzall and a 4.5" grinder with a cut off wheel. A plasma cutter would be best, but I aint rich enuff to have one of them....
    j
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    man i wish, if i did need anything else /forums/images/graemlins/rotfl.gif
  6. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    I have had some pretty good luck with an angle grinder and a 1/32" cutoff wheel. Really clean cuts and doesn't seem to break the wheels as easily as I thought it would. Downside is cutoff wheels that thin are hard to find, 1/16" are all over the place and work pretty well also.
  7. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    how much are you gonna trim? i wanna trim my fenders too.... please mommy?? can i can i can i? hehe, die grinder sounds like a good idea /forums/images/graemlins/thumb.gif
