Cutting thick steel
Discussion in 'The Garage' started by CHEVY 4WD, Jul 22, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    whats the best way to cut curves in trick steel?(besides a plasma cutter)
    Im planing on cutting down the 14bolt FF and I want to do it like a 13½ bolt except for I want to go AROUND the bolt hole im gonna use a washer as a steincle(put 1 bolt and washer in with out the cover)
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    die grinder, cut it out in chunks..or use a grinder...
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    laser cutter /forums/images/graemlins/grin.gif but im sure u arent on a $50,000 budget so i would say a die grinder is your next best option. quick, cheap, easy...
    NITRO
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Use a cutting torch, and then grind it down to smooth to perfection. /forums/images/graemlins/eek.gif
  5. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    I do have access to a tourch but never used one you think it will really work well for that thick of steel?
  6. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    it depends on the hardness and the tip and the thickness.
    NITRO
  7. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    You can easily burn steel up to 2" in thickness. Just depend's on the tip. The harder steel is, the easier it cut's.
  8. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    ohh thats cool sounds like a really good way to do it BUT like I said ive never used one
  9. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I thought the diff cases were cast iron. Cutting torches don't do well on cast iron...but I may be wrong and it may just be steel.
  10. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    hey don, ill send ya a piece of T1 steel and see how long it takes ya to cut it......for some reason...this [I love Jeeps] takes quite a bit longer than other regular cold rolled steel. its some tuff [I love Jeeps] man.
    NITRO
  11. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    is this what you are talking about? /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  12. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    T1 ain't no big deal to cut with a torch...I've cut 3" thick T1 with a propane torch (fairly large tip though).
    Cast doesn't cut nicely with a torch though, even if it's ductile cast it still doesn't cut nice at all...just kinda melts and blobs/forums/images/graemlins/eek.gif
    I'd use a small grinder, there really isn't that much material to remove. Or you could pay a machinist to mill it down for you like what Tony did /forums/images/graemlins/thumb.gif although I think Tony has his own milling machine. /forums/images/graemlins/cool.gif
    rene
