Cutting threads further down a ubolt?
Discussion in 'The Garage' started by TravisO, Oct 18, 2006.
  1. TravisO
    TravisO 1/2 ton status
    Apr 17, 2003
    143
    Aloha, OR
    Is there any good reason not to do this? I have a 14 bolt from a one ton that I am putting under my 91 K5. The ubolts I grabbed from the junkyard seemed like a good thing to grab at the same time. The spring pack must have been much thicker than the 4 leaves I am using without an overload. I was gonna buy new ubolts but thought I could at least try running these stock ones with threads cut further down. Any objections?
    Travis
    BTW, there are already rolled threads on there. Hint, hint.
  2. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    Don't do it you're just wasting a good u-bolt, I just learned this lesson recently.
    I got a good deal on a set of new u-bolts recently that were cheaper because they had cut threads - I stripped them out using only a short handled 1/2" ratchet. :eek: Did I mention they were 3/4" dia u-bolts? :eek: :eek: I learned a good one, threw the rest away and bought rolled thread u-bolts.
    Long story short... I'd buy / find the right length u-bolts.
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    With rolled threaded u-bolt, you will find the diameter of the shaft of the bolt to be smaller than actuall size of the threads. This is because when you roll threads you displace (sqeeze) the material in to the shape of the thread.
    So, if you try to cut threads on that same shaft the O.D. of the threads will be to small. And you will have a Very weak u-bolt.
    In other words DON'T DO IT:D
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    dont use used ubolts. they'll stretch and loosen up, not to mention with the stress that has been on them for god knows how many years, they may just snap. they're too cheap not to replace them.
  5. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    The place I use charges $10 a bolt with nuts and washers. thats way to cheap to reuse an old bolt. Plus I don't even think about fighting to get the old ones off. I just cut them everytime if they even think about being difficult.
  6. TravisO
    Apr 17, 2003
    143
    Aloha, OR
    Ordered the 14 bolt ubolt flip from ORD. Had them dig up a special length
    for my application. $78 shipped to Oregon. I guess I can live with spending that much if I don't have to worry about bashing my nuts on the rocks. Hey, sounds like I made a new sig line for myself.
    Travis
  7. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
