Cutting up my tires
Discussion in 'The Garage' started by BLZN4FN, Aug 16, 2006.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I just won a Tire groover off e-bay. I have a set of 39.5 tsl bias plys do I cut all four or only the rear tires? let me know what you have done and how the tires worked after the cut:D
  2. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    How much did you win the auction for?
    Oh, and I'd do all four.
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Cut all 4.
  4. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    X2:D
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    All four.
  6. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    Most of the ones I have seen have been all four, at places like ORD and such.
  7. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    dont go too hot or youll break the blade and theyre expensive, make sure you dont hit the belts its junk if you do. i do this for a living on truck tires and be very steady and take your time, low heat and slow lines will make everything last longer and come out better. dont try to go as deep as possible but leave a bout 3/32" of undertread so they dont seperate form the belt package.
  8. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Get a sharpie and mark out your pattern on the tires before you make the first cut. Then you can make changes if you want
