Cutting Weight
Discussion in 'The Garage' started by jekquistk5, May 22, 2006.
  1. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,025
    851
    Pinckney, MI
    I plan on making my k5 just a tad bit lighter :hack:
    which involves ditching tailgate, doors, top etc. I plan on doing this to help while trailering, and on trails etc. Other then cutting all sheetmetal off where else can I shave weight??
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    seats, people, gear, spare, interior trim...
  3. jekquistk5
    Jan 18, 2004
    11,025
    851
    Pinckney, MI
    rear seat is out, I only cary enough tools for me to do the basics, well I never go out alone, so Most of my group caries the stuff I do not bring.
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Tools? Heavy spare parts? A/C system? Just a few ideas.
    Ah, I see your reply about the tools.
    Another thought, a full tank of fuel is very heavy.
  5. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    sway bar...
    swap to full convert..
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Aluminum wheels
    Aluminum heads
    Aluminum block
    Aluminum waterpump
    Aluminum radiator
    Tube bumpers (kinda prerunner-style) instead of plate bumpers
    No exocage
    Smaller fuel tank/fuel cell. Gasoline is approx. 6lbs/gal, so 5gal. less is 30+lbs saved...
    Smallest battery and alternator you can get away with
    Lexan windshield instead of glass
    There's a huge thread on this subject in the Center of Gravity forum...
  7. jekquistk5
    Jan 18, 2004
    11,025
    851
    Pinckney, MI
    Ahh should have looked there my bad. I have not wheeled with the top off, doors off or tailgate off yet so we shall see what happens. I will probably take the AC stuff off, but then add a york compressor so yeah. Sway bar is gone allready
  8. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    The guy who had my truck before me was on a weight saving trip...he took off the steel plate that protects the gas tank...Not a good idea...
  9. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Interior stuff weighs a lot. Get rid of any brackets or wiring you're not using. You can eliminate ductwork also. I don't even run sun visors. A radio, speakers, and wiring can be an easy 30lbs.
    I run empty doors (no glass or regulator) and they're easily half the weight of stock. Without the door panels or door lock release they're even lighter. I run factory doors, mexican doors are even lighter.
    I have the cab on my truck light enough that my Dad and I can carry it around if there are no doors on it.
    Cut off crap you don't need like brackets and whatnot. Anything you can replace with plastic or aluminum is a bonus. The front clip of a 70s pickup easily weighs 100lbs more than an 80s pickup.
    More important than the weight is where you have the weight. Anything heavy should be mounted low. That means winshield washer reservoirs, coolant reservoirs, batteries, and gas tanks should all be mounted low.
  10. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    JUST DONT DITCH THE COOLER!!!!
  11. jekquistk5
    Jan 18, 2004
    11,025
    851
    Pinckney, MI
    I generally do not carry a cooler, just a jug of water and thats about it. oh and every fluid that my truck takes.
  12. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    one way to ditch some weight is to take some of those parts that are laying in the back of your k5 and actually use them :whistle: :rotfl: :rotfl:
  13. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,803
    388
    Clayton Del
    Lite beer helps!!!
  14. RootBreaker
    Nov 29, 2001
    5,117
    173
    that is kinda where I was going with the cooler joke... you can ditch spare parts, tools, spare tire, passenger, seats... BUT KEEP THE COOLER!!!! :haha:
  15. FOR MUD
    Apr 6, 2006
    2,803
    388
    Clayton Del
    How about the front seats . Fiberglass racing seats must be lighter . A big joke at work is if you get hurt and get put on light duty , it means you have to switch to lite beer .
  16. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    cut cut cut
  17. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    what about carpets? wouldn't rihno lining be lighter? or about the same?
  18. RootBreaker
    Nov 29, 2001
    5,117
    173
    ummm we are not really talking about a real truck here now are we???
    a rc car maybe???? :haha:
  19. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    what about wheel wells if left intact they are a good amount of weight...ditch them
  20. jekquistk5
    Jan 18, 2004
    11,025
    851
    Pinckney, MI
    Thanks TJ I will consider that.. You get your clutch fixed yet???
    Carpets will be 100% out this weekend. found out I need to do a small floor repair. Seats is another thing, but I was actually thinking about putting in seats from a 99 grand am in. I am doing bedliner on the inside just to prevent rust and making cleaning easy. Wheel wells I shall just have to wait and see till I get the 38.5's to know how much to cut.
