CV/ Cardian Drive shaft- Must the pinion be straight ?
Discussion in 'The Garage' started by Pookster, Sep 9, 2003.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I finally installed my Double cardian drive shaft. It fit fine, but I am still getting a vibe. A different kind of course. My question is, must I tilt the pinion so that it is straight with the drive shaft?
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    that is my understanding, point the pinion directly at the transfer case,but down 2 degrees for axle wrap. with a non CV shaft you want both u-joint angles equal ( down at the transfer case, up at the pinion) to within 2-3 degrees for a vibration free shaft.
