CV driveshaft idea
Discussion in 'The Garage' started by sandawgk5, Nov 2, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I was told that the ujoints in a front CV shaft is S44 from the factory. If this is true could I not take the CV from a front shaft and put it on my rear shaft which is also S44 joints? I know it is not orthodox but it is cheap and will get me by until I finalize my DL lengths and can get HAD shafts built.
    Go ahead and bust my bubble. If it can not be done please explain to me why. I think I can put the CV in the rear driveline and put my existing slipyoke infront of it I think it will also give me the extra length to swap my 56s backwards.
    Ira
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Sure you can do it. But you need slip-yoke that has the centering ball ;)
    FWIW, some old Cadillacs used a double-cardan with a slip joint. Not sure on the joint size, and I don't imagine its good for much angle.
    Here's one of the cheaper ways you use the S44 double-cardan on the rear:
    http://www.arizonadrivelines.com/drive_shaft_SYE.htm
  3. sandawgk5
    Oct 28, 2003
    6,881
    OK I am stupid why do you need a centering ball? what would happen if I just put my yoke on it. I also remember someone who sold just the yokes but I cannot seem to find them. The link is you supplied is for eliminator kits and slip flanges for 1330 and 1350 CV with a smaller pilot diameter.
    Ira
  4. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    You can get a slip yoke for the CV.
    This is the shaft I've been running in the rear of my Marvzda. It uses the Saginaw CV on a slip yoke rear shaft.
    Only problem I've had is that this CV has limited "angle" capability - and I've busted the CV 2 times now.
    Marv
  5. sandawgk5
    Oct 28, 2003
    6,881
    The cost of the Slipyoke is probably close to the price of having a CV shaft made with larger than S44 joints also eh? Where did you get said slipyoke and what is not much angle. I run 56s in the rear and get about 12" of travel. Man it looks alot more than 12 but I do not max out my 12" travel shocks when the truck is on jackstands I have about 1" left in them. Any info you have would be great I am just trying to think out of the box.
    Did any vehicles come with CVs in the rear that I might find in a junkyard?
    Ira
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    A bunch of the largest GM cars used the set up in the diagram. Look for the biggest Buicks, Olds and Pontiacs from the late 70s, early 80s.:D
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I don't think , from what I read on here , and at HAD website , that the GM rear yokes in the RWD cars were NOT splined all the way .
    My rear shaft has an aftermarket slip yoke that is splined all the way . Some shops will sell just the parts , but you gotta search them out .
    In a rear Blazer , shackle flip with stock 52's , stock shock mount locations and gabriel shocks , I have never had angle problems from a s44 CV .
    I have however blown up a greaseable u-joint there ( all I had ) so run Spicer or Brute Force .
  8. u2slow
    May 9, 2001
    2,217
    BC Canada
    Essentially the same as running a 2-piece rear driveshaft without a support bearing. :crazy: (Albeit the one piece is very short.)
    I'm not up on the pilot diameters. Perhaps they make one of those for the S44 double-cardan also.
