CV driveshaft question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigjbear, Aug 14, 2002.
  1. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    I just pulled my front shaft and I think I may be in luck. The centering ball looks ok, but I haven't pulled the u-joints yet. So I might be able to just swap the u-joints, right? What should I look for on the ball? The shaft is from a '73 NP203 w/ a Spicer style output yoke. TIA.
  2. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    Anyone?
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You can get a rebuild kit for the centering ball. They are a pain in the a$$ so you might as well while you are there. There are some needle bearings and a spring that no matter what you do, will just go everywhere. Can you tell that I like them?
  4. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    Pulled it apart and the centering ball needed replaced,too. That actually turned out to be the easy part. The casting where the clips snap in cracked. Oh well, thats what welders are for /forums/images/icons/wink.gif
