CV joint or not?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mkmiller, Apr 17, 2002.
  1. mkmiller
    mkmiller 1/2 ton status
    Oct 31, 2001
    306
    Magnolia, Arkansas
    I've been wanting to know what the advantages are to having a CV joint in the front driveshaft? My '71 has one with the 203 transfer but I'm swapping in a 205 out of the '69 and it's front shaft doesn't have one. Is this a necessity? I'm looking at putting a 4" lift on the '71 next year and I already have a 1" body lift if that matters. Any help is appreciated.
    Matthew
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    you will need one with the 205...especaily if you lower your transfer case when you left the truck...the front yoke will be aimed up slightly so the angles would suck ass if you dont have a c/v for the front.
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    You can live without it. You would be better off with it. 72THING has 6" front springs and no CV....but lots of clearance grinding to make the angles work.
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I have one on my front 205 output. I don't knwo the answer but when I bought my K5 in 93 it did not have one in front and I could not go over 10mph in 4x4 without a serious vibe out front. A new CV & shaft fixed ALL the vib issues. Oh and I did not lower my Tcase mount with my 4"Rancho lift....
    I recomend getting one.
