CV joints on a slip yoke
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Jul 5, 2001.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I noticed a place in the back of 4wheel mag that says they can do a CV on a slip yoke for the 208. I thought this was only for a foixed yoke? Anyone have one or any info on this?
    Brent
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i have a CV on my 88...it also has a slip yoke and it works well....the only prob i have had is when i jumped it...when i landed the shaft was just a little long so when i hit the cap on the end of the slip yoke poped off and now it leaks all the time....other than that it sould work with out any problems at all
    Donations accepted for the "Build Chaz's 1972 K5 fund"!!!
  3. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    You can run a cv with a slip yoke. They usually run a R3 joint wich is 1/2 ton stuff. You cant run a 1350 cv wich is 1 ton.
    MAC
  4. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    my CV is one from a 1 ton F350. 1350 u joints and all...
  5. 4xmac
    May 1, 2000
    82
    Calif. Oceanside
    BIGBLUE, are you running that shaft on a 208? I was told by Jessie that a 208 from a Blazer cant run a 1350 cv. They use a 3R joint which is basically a 1310.
    MAC
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Mine is from Tom Wood's driveshafts and it is excellent. You can see pics of my drive shaft at http://www.geocities.com/milnerlives_2000/blazer.htm
