CV or shims? Driveline help?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GRINCH, Jun 9, 2001.
  1. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Now that I installed the ORD Shackle flip with 1" add a leaf, I have bad vibes. Should I mess around fighting this or just fork out the cash for a CV type. I read a few posts on this and theres not enough info out there. Has any body really solved the vibration problem?
    The Few, The Proud, The K5 Blazer
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    It kinda seems like this is a common problem... I don't even have a shackle flip but I went with a CV shaft to avoid vibes and to try and eliminate shims up front
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  3. GRINCH
    Jan 30, 2001
    1,951
    Helena, MT
    Where did you get it from? How much did it cost? What if I want to change out my worn out 4 " springs will I have to get the rear drive shaft redun?
  4. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    I got mine from Tom Wood's driveshaft... but you can also talk to Jesse at highangle. It's pretty spendy.... about $300-$400 range. If you go 4" you have no worries really... Even w/ a 6" lift it isn't really necesarry but I decided I wanted to not have to deal with vibrations and am going to try and run none to very little shim up front to keep my angles sane for handling.
    -Mikey
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you have the money i would go with the cv joint
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>
  6. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Hey Dennis,
    I have the Shackle Flip on my truck with a custom 1.5" add-a-leaf that relocates my axle back 1.25"
    I had very bad vibes untill I put in a C/V shaft. The shaft I went with was the 1 Ton C/V Shaft from Jess at <A target="_blank" HREF=http://www.highangledriveline.com>http://www.highangledriveline.com</A>.
    Once I put it in the truck ALL of the vibes went Bye Bye. Now I have a huge driveline with 1350 joints everywhere and no vibes. I love it. Hope I helped.
    P.S.
    He also gives members of CK5 10% discounts.
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
  7. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    If you have the automatic hubs make sure you back up after you take it outa 4x4 or you'll get vibration that sounds just like your drive shaft.
  8. GRINCH
    Jan 30, 2001
    1,951
    Helena, MT
    I sent jesse a P.M. Still haven't heard from him yet!
    Thanks for the info. I will probably go with the C.V.
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    He will answer but give him a call for quicker results.
    He will suggest a slip-yoke eliminator kit to get a true CV joint driveline. And you need to drop the transfer case to install the kit. Hold on to your shorts for that quote. It is what I am going with for the extra strength and elimination of the slip yoke and its associated problems.
    Dave
    "Visualize Whirled Peas"
  10. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    Call Jesse at his shop...530-877-2875. He is very busy, so he doesn't get to check his messages here very often.
    Jeff427
    <font color=red>Mud Dog Off Road Club</font color=red>
    http://lyonsdesign.bigstep.com
