CV = pinion oiling problem??
Discussion in 'The Garage' started by BL1TZKRIEG, Oct 28, 2005.
  1. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    hi, I'm thinking about getting a cv driveline made for my blazer.
    after I put on my 4" ord shackle flip it set up my pinion angle perfect for a cv.
    It's around 16* will that fry my pinion bearing from lack of lubrication, it's a 10 bolt by the way. I want it to last a long time.
    I would also like to add 1" zero rate so I will have 5" total lift
    It will mostly be driven on the street
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mine is coming up on 2 years in February with a flip , around 5 inches of lift total ( echobit kit ) . I have no problems with mine . The fluid whips around when ya roll forward , plus when ya brake , due to inertia , the fluid goes right up into the pinion area anyway :D
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah, I wouldnt worry about it either. You fill it up and the oil doesnt have that many places to go, its going to get oiled. If you worried about it that much, overfill it a little.
  4. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    thanks I just wanted to make sure :)
