CV shaft/degree shim?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CaptCrunch, Jun 9, 2001.
  1. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    To anyone out there running a rear CV shaft... how many degrees did you go to point the pinion up... thought I have heard 6, but not sure...
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  2. NOT4SHW
    NOT4SHW Guest
    It depends on the amount of lift. I'm running a 4 degree shim with 8" springs and 2 1/2" flip kit but I'm going to 6 degree because 4 isn't enough.
    '79 K5,13 1/2" lift, 39.5 TSL's,15x12 Eagles,350,t-350,warn 8274,
  3. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    I believe it also depends on whether you are running a flip kit or not too. Since the flip kit rotates the axles also. I am running 4 degree right now with 2" spring, 4" ORD flip, and 1" ORD zero rate add a leafs and an extra leaf out of my stock spring pack. I will be switching to a 6 degree shim soon b/c my pinion angle is still off.
    <A target="_blank" HREF=http://www.geocities.com/jmargtx/index.html>http://www.geocities.com/jmargtx/index.html</A>
  4. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    I'm running Blocks for the moment w/ a 6" lift.... also have ord zero rates in back.
    -Mikey
  5. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    i will tell you from first hand exp- if you put an ORD cshckle flip, with stock springs and a 14 blt ff, the pinion will point pretty much toward the t-case. is it possible to make a cv joint using a stock d-shaft and a front axle cv connected to my 241 slip yoke???
    AIRBORNE!!
