CV Shaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FL84K5, Mar 27, 2003.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Can a slip yoke style driveshaft be converted to a CV shaft? Thanks.
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    yes it can. i had a new one made up for my /forums/images/graemlins/k5.gif but the shop told me they could have used my old one to make it too.
  3. agk5
    agk5 Registered Member
    Mar 23, 2003
    14
    College Station Texas
    Im just guessing you have a 208 t case and are tired of vibes that come without a cv on the rear shaft. I have a 208 case and a 4" lift, and the vibes can get bad, and im looking for a solution. If a cv joint can be built into the shaft along with the slip yoke on the back of the t case, this could solve my problem. Otherwise i was looking into a 350/205 swap. Is this what yall are talking about, and if so how much improvement did you see? Thanks for clarifying this for me
  4. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    Yep, I'm running a 208 case. I'm running about 6 inches of lift in the rear by way of an Echobit shackle flip and an ORD zero rate. I had the drive shaft lengthened by an inch, which helped some of the vibes. If I can't shim the rest out, I'm going to most likely have the shaft converted to CV.
  5. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    when i put my cv shaft into my /forums/images/graemlins/k5.gif it eliminated all of the vibrations i was getting. the shop also lengthened it by an inch or two, i can't remember for sure. i'm running a 700r4 with a 208 also.
  6. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    You still fighting this? I still dont understand whats going on. 8 inches and no vibes at all in PI, but youve riden in it a few weeks ago and know that already. /forums/images/graemlins/thumb.gif
