CV shafts - changes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Dec 20, 2001.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    Allenton, MI
    When I put the 14 bolt under my Jeep, I went to a CV shaft in the rear. I changed the output shaft of the 205 to accept the CV shaft. The front was not needed.
    Now that I am putting the drvetrain in the Blazer, I wil just get my rear CV driveshaft extended, easy. But, I am thinking I will also need to goto a CV shaft up front.
    Am I correct to assume I will need to change the front output shaft of the 205 like I did the rear? If so, anything differant that I should know?
    Ken H.
    '86 K5 in parts
    1-ton 44 TSLs
    454 BBC, 350 trans, 205 transfer
    Rust free in Michigan!
  2. RaisedK5
    RaisedK5 1/2 ton status
    Long Beach, CA
    Check out the 205 info section on ORDs site, they list all the yokes available for each shaft, i think its somehting like, 10 spline will take a 1310 ujoint or spicer cv, and the 30 spline will take a 1310, a larger one, a flange for the Saginaw style cv, and thats all my fuzzy memory can recall , but ya they spell it all out on the site.
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
