CV ????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dammit32, Sep 14, 2002.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    Do these eliminate vibes from the driveshaft or just put up with them?
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    They tolerate more in the vibration department. They have to be setup correctly too in order to eliminate vibrations.
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    They eliminate vibes by counter balancing them at one end as opposed to counterbalancing them through both ends, by making the pinion point straight down the shaft the last u-joint doesn't induce and imbalance. The CV has an internal locator joint which automaiticly balances the two angles. The same can be ocomplished by creating equal but opposite angles at each end of a non-cvshaft so they balance each other out, but extreme angles are harder to balance than a CV style shaft.
