Cylinder honing help?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BayouBlazer88, Jul 15, 2003.
  1. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    This is my first time doing it, so is there any thing I need to look out for? How fast does the drill need to go and for how long do I need to hone each cylinder?
    -Also, is TDC when the cam sprocket is in the 12 o'clock position or the 6 o'clock position? I think its the 12 but the Haynes manual wasn't very clear on it. Thanks.
  2. dyeager535
    26,979
    timing gears are typically installed with the cam gear dot facing 6, crank gear facing 12, and then of course, 6 and 6 is TDC #1
  3. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    sorry I didnt totally understand your reply. I know the sprockets are installed with the cam at 6 and the crank at 12. So your saying this position is also TDC for piston #1?
  4. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Line up the dots by placing the cam gear dot at the bottom (6 o'clock) & crank at the top (12 o'clock). This will install the cam correctly. It is #1 top dead center, but not #1 TDC compression. To get #1 TDC compression rotate 1 turn so that both dots are facing the top (12 o'clock) this is where you can install the distributor with rotor pointed at the #1 plug terminal.
  5. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    If you are using a dingle-berry style hone you want to keep your drill speed down to around 500 RPM or so and do each cylinder for 30 to 45 seconds while continously creating a cross hatch pattern ( 45 degree ).Don't forget to go into and out of each cylinder while the drill is spinning .
    The lubricant is a big topic of debate among mechanics but I use 30 weight oil mixed with Marvel Mystery Oil as my lube . Good luck , Tom
  6. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    When honing your looking for a tight cross hatch pattern. Use a dingle ball hone and clean it in some solvent each cylinder that you hone. Then reoil it when honing the next cylinder. What the solvent does is clean off the impregnated metal on the balls. I used the Marvel mix also when honing. The last thing I do when honing is go in reverse for about 15 or so seconds and work the hell out of that hone(up and down) as fast as you can move. It gave me the perfect cross hatch pattern. I learned this from my school instructor who has rebuilt a ton of motors. Do not use a stone hone unless your very steady. Any angularity using a stone hone will cause a poor cross hatch and remove too much material. One last tip is to use marvel mystery oil when installing pistons instead of regular oil. Just something I do.
  7. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    Thanks for the info. I had originally bought a stone-type hone but I'll soon and go exchange it for a dingle ball hone. Also, what solvent would you recommend me use to clean off the hone? Can I use carb cleaner or is that too harsh? Thanks.
  8. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Cleaning with solvent between each cylinder is a good tip . Mineral spirits is a pretty good and cheap solvent to use . If you are going to soak your hands in the m/s than add some ATF to it to keep your hands from drying up - just a trick of the trade . HTH , Tom
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Definitely use a ball hone if you're new at this. Stone type hones work very well (better than ball hones IMO, as long as the cylinder is straight and round) but if you've never done this before, you're MUCH better off with a ball type hone.
    Good luck and go for it. I wish I had the cash to build another motor right about now with all the problems I've had with this used one I got for free.
  10. thefarside
    thefarside 1/2 ton status
    Jun 27, 2003
    343
    Vernon, CT
    When would a person use a stone hone? A score in a cylinder maybe? Or is the stone hone mainly ment for shops with the equipment to use them?
  11. thefarside
    Jun 27, 2003
    343
    Vernon, CT
    I found this company on the net, quite intersting.
    web page
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A stone hone does a better job of honing the cylinder if it's perfectly round.
  13. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I never could find a ball hone anywhere where I live, anyone have any tips?
  14. slider
    May 7, 2001
    547
    NAPA auto parts, I am sure almost all good auto parts stores can order you one. check out some of the mail order go fast parts stores. Doug Herbert is someplace back there summit, Jegs, Northern auto parts, PAW engine parts etc.
  15. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Are you building it in Lafayette? I could come give you a hand. Let me know. /forums/images/graemlins/thumb.gif
  16. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    Yeah I'm building it in Lafayette. I live around Dulles drive which is west of Ambassador Caffrey, almost in Scott. I appreciate the offer but it looks like I'll be letting the machine shop do the cam installation as well as the cylinder honing, since it would cost just as much to let a pro do it as it would to buy the tools. But if I need a hand in the future or if you need any help, let me know.
