Cylinder inflation tool?
Discussion in 'The Garage' started by Thumper, Jun 21, 2005.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I am about to embark on a new valve stem seal replacement with the motor in the truck, and heads on the motor. So I have to hold the valves up while I change them. A buddy used to have a spark plug changed into an air fitting... he could pressurize the cylinders with the compressor, and replace anything with out losing the valves. My question is: should I still rotate the engine to have every cylinder at TDC while I do it? How much pressure would it take to hold the valve up?
    Thanks!
    Mike
  2. ryoken
    Jun 13, 2003
    29,622
    1,373
    Jersey Shore
    i don't bother spinning it over, i leave the pistons whereever there at.... but you could do it to be safe.. i just don't for the time savings... haven't had one drop on me yet...
    i made up a one-way valve fitting that i put on my compression tester hose to do it.. usually i'll bring my portable air tank out to the boat with about 70, 80 lbs in it...
  3. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    air fitting...
    They sell special fittings with spark plug threads that go on your air hose,but its not really a must have--I usually screw the fittings that "quick dissconnect" on the air hose directly into the plug hole--they are 1/4 inch pipe thread,not 14mm like a sparkplug,but they screw in (finger tight is enough!) and work fine for me just as they are--if you desire,you could bust the porcelain out of an old plug and grind off the ground electrode and tap it with a 1/4" NPT tap,and use that--thats what they sell you as the "special fitting" basically....
    Or spend the 10 bucks for a ready made one--I never had too,and I've done 20+ valve stem seal jobs....I've even stuffed nylon rope in the sparkplug holes and turned the engine over by hand until the piston squishes it against the valves--then you KNOW they arent going to drop in the cylinder,and ruin your day,or night!...works without an air compressor too!...
