cylindrical hole on cap/cover
Discussion in 'The Garage' started by tdengines, Apr 20, 2007.
  1. tdengines
    tdengines Newbie
    Mar 28, 2007
    4
    Pennsylvania
    I have a 1984 Blazer. On the driver's side of my cap, there is this hole, about 3 inches across and 2 inches deep. It has some metal fittings or contacts in it. Can anyone tell me what it's for? Is something missing from the hole?
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Should be the wiring for the dome light in the back....
  3. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    What cap are you talking about?
  4. tdengines
    tdengines Newbie
    Mar 28, 2007
    4
    Pennsylvania
    What cap am I talking about?
    The fiberglass cap/shell/cover that is mounted over the rear of the Blazer, covering the rear seat and bed.
    The whole is actually about 2 inches across and one inch deep (now that I take another look at it). It's on the back portion of the front of the frame of the cap, behind the driver's seat.
    And I thought the cargo light wiring was overhead center according to the instructions for removing the cap in the manual.
  5. dyeager535
    26,975
    Nope, there should be a white metal plate screwed into those metal pieces. It is most definitely for the topper light. Wiring comes up from the side panel (as I recall) and goes into that panel, where there is a black plastic connector. Pull the connector out, disconnect from the ropper end, you can remove the top. :)
