d 44 8 lug conversion ?
Discussion in 'The Garage' started by bigrollin76, Feb 16, 2005.
  1. bigrollin76
    bigrollin76 Registered Member
    Feb 15, 2005
    26
    phoenix
    what do i have to get. aproximetly how much is it going to cost new or used. anyother suggestions. 350/350/203 14 bff, 3" spring, 3" body, 76 blazer.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    do you just need to convert your existing D44 over to 8 lug or do you need a whole new frontend? Converting it is easy. All you need is the 8 lug hub & rotor assembly (not locking hub) and brake backing plates as long as you get the stuff from the same kind of axle you have. Internal vs External locking hub.
    Harley
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
  4. bigrollin76
    Feb 15, 2005
    26
    phoenix
    i just need the inner hub assebly. trying to figure out if the spindal is difrent from outer hubs, outer shaft and bearings. thx
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    do you have an internal locking hub axle now or an external locking hub axle. The spindles are the same as long as you use parts from the same style hub. If you have an internal hub then your current spindles with work with an 8 lug conversion as long as your donor parts are also from an internal hub. The brake caliper backing plate is also different from 6 to 8 lug along with the hub and rotor assembly.
    Locking hubs are the same as long as you don't cross styles internal to external.
    harley
  6. bigrollin76
    Feb 15, 2005
    26
    phoenix
    ive already got external hubs i need the internal hubs. how much do they cost new or used. do you know anyone who has them for sale. thx
