D 60 Caster and Camber specs
Discussion in 'The Garage' started by K5MONSTERCHEV, Mar 2, 2004.
  1. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Ok guys I need some specs.
    First of all, whats the Caster and Camber specs for a Dana 60?
    Second, I know I should add Caster soooo, what would you guys reccomed to set it to? And what would you reccomed the Camber?
    Before you start telling me how I cant adjust it, Im getting knuckles pressed on an axle, so i can set it to whatever i want.
    Thanks in advance!! /forums/images/graemlins/thumb.gif
  2. MR4WD
    MR4WD 1/2 ton status
    Jul 28, 2002
    133
    Fort McMurray, Alberta.
    You can't adjust caster. 3-5 degrees of camber.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You can adjust caster with the length of your shackles or with shims.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    or by cutting the knuckles and turning them, which is exactly what he stated he is doing
  5. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    I think you got the terms mixed up, switch them around and youre partially correct. You can adjust camber with shims that go behind the spindle. I dont know what the camber spec is but I would assume 0.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I was thinking he was referring to spindles, oops. /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I am not sure on camber specs but for caster 8-9* is what is called for on a 1 ton with a D60. /forums/images/graemlins/thumb.gif
  8. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Wouldnt i want to add caster, since im all lifted running big tires?
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    fill in your theory on that topic
    I have seen someone theorize that larger tires are like more caster
    the contact patch distance from the X (lost the wording mid thought) is greater the larger the tire
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Im not 100% sure, thats why I asked. I had heard that, and the place putting my knuckles on asked me about it.
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I would aim for 8*
    I think that is where mine landed
