d 60 conversion
Discussion in 'The Garage' started by big_bad_blazer, Jun 22, 2003.
  1. big_bad_blazer
    big_bad_blazer Registered Member
    Sep 19, 2002
    22
    yankton, SD
    ok after i get my tranny and t-case rebult i am going to start on my d60 conversion. i was just wandering if you have done this do i need new drive shafts u joins and spring or is it just slap the axles on. i have a 203 t case if that helps. i was just wondering so i get all the parts befor i do it. that is the easyest way. waiin for parts makes me mad. thanks fora ny help
  2. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I just did this... contact stephen at ORD, our site moderator... he had everything to make it a bolt in and had lots of good ideas... and I didnt have to shop around..
    took about an hour to do... 45 minutes to show the wife which tool and 15 to actually do it (I do however have a well equipped shop/lift/jacks/ air) so if you are backyarding it you and a couple of buddies and 2 hours
